Nictrix said:M Sport seats too, is it not?Maniac said:Interesting... SE interior with M sport bumpers, an upgrade by the previous owner perhaps...
Maybe it is an M Sport but the wheel and gear knob has been swapped.
Maniac said:Nictrix said:M Sport seats too, is it not?Maniac said:Interesting... SE interior with M sport bumpers, an upgrade by the previous owner perhaps...
Sport seats were part of the pure white design interior. It's either someone put m sport bumpers on or put an SE steering wheel on. Not sure why you'd do the latter.
mr wilks said:I'm a big fan of the style 296 but if you feel the need to change then against the DSB paint I would be looking for some silver to contrast
First 2 are safe bets for a OEM look , the 3rd choice ive seen on a dark coloured E89 & they looked terrific
http://www.cmwheels.com/index.php?route=product/product&path=60_91_92_302&product_id=914
http://www.cmwheels.com/index.php?route=product/product&path=60_91_92_302&product_id=89
http://www.bmautosport.co.uk/showroom/product_info.php/new-lrn-blade-alloys-hyper-silver-wider-rears-p-3952?cPath=51_27_194_198_294
Sgreen said:If you like the 296 why not go for non run flats, supposed to help against the cracking issue.
mr wilks said:Sgreen said:If you like the 296 why not go for non run flats, supposed to help against the cracking issue.
For sure a good move to get those off :wink: I would also look to up the profiles slightly to 35 on the rears & 40 on the fronts , helps with comfort & reduces arch gap![]()
Marlon said:mr wilks said:Sgreen said:If you like the 296 why not go for non run flats, supposed to help against the cracking issue.
I like the idea of increasing the profiles to reduce the arch gap on my SE Andy, this is something I'd consider when my tyres need replacing. Could I do this in two stages - maybe fronts first? If this is sensible what profiles would you recommend?
MACK said:Marlon said:mr wilks said:For sure a good move to get those off :wink: I would also look to up the profiles slightly to 35 on the rears & 40 on the fronts , helps with comfort & reduces arch gap![]()
I would go with the M spec tyre sizes, some on here have and have noticed a difference to ride quality as well as arch gap. So thats 225x45 on the front instead of 40 and 255x40 0n the rear instead of 35. It makes about 3% speedo difference, however as our zeds under read to start with it actually makes the needle more accurate! Only issue is the M tyre sizes are quite a bit more expensive than the standard zed one. Are you running non runflats Marlon?
Marlon said:MACK said:Marlon said:I like the idea of increasing the profiles to reduce the arch gap on my SE Andy, this is something I'd consider when my tyres need replacing. Could I do this in two stages - maybe fronts first? If this is sensible what profiles would you recommend?
Yes on standard Vreds MACK, which I'm very happy with.
enzed4 said:Beautiful car - congrats on the new ride. Just wondering though, isn't it a twin screw single turbo, not a twin turbo?
Very jealous, regardless :lol:
mr wilks said:Marlon said:mr wilks said:For sure a good move to get those off :wink: I would also look to up the profiles slightly to 35 on the rears & 40 on the fronts , helps with comfort & reduces arch gap![]()
As Mack points out its a simple move up to M profiles & something ive done a few times with only positive results
The rears on MV2s being 8.5j against a 224 being 9j I would look to go with 245 40 18 which works a treat Colin
I see the Vreds are heading up pricewise & for good reason , id say as close to a Michelin for 25/30% less :?
A set of Uniroyal RS3s on 45 & 40 profile comes in around £100/£120 less & I doubt you would be disappointed with them
