keving1 said:Can anyone help as I plan to try to do this today.
Do I have to move the steering rack and is the install the same as the 335i/135i?
keving1 said:Thanks John for the reply, my zed is on axle stands at the moment and I have had a look at the job and yes it is tight.
Does the steering rack need to be removed as in the 335i/135i or does it stay in place?
R.E92 said:I wouldn't trust any old garage with the install. It's a real s**t of a job with plenty of opportunities for mistakes. Personally I'd only trust the likes of Darren Wood or Birds with this job.
I went for the DIY option. The install was probably around 8 hours. I then realised that one pipe was touching the subframe causing a rattle and my vband clamps weren't on correctly. The second time around it only took 3 hours. It's pretty horrible without a lift, lots of scraped skin and swearing involved.
The common install problems are:
-vband interfering with wastegate actuator
-leaks from vband or gasket
-O2 sensors getting either damaged or replaced in the incorrect places
-pipes touching the engine mount heat shield or subframe
The right-hand drive Z4 install is probably the most tricky of any downpipe install for a N54 engine, there's not a lot of room and you have to be really aware of clearances to avoid rattles.
R.E92 said:I didn't drop the subframe but it may have saved me time and skin. I just unbolted the steering rack and moved it forward (just 2 bolts)
The trickiest bit of the whole job is getting the vband clamp to seat and tighten correctly on the rear turbo. You have to do it from above but you only have visibility of the band from below so manoeuvring it is just torture. I have big hands so they don't really fit between the steering column and the engine well.
It's the perfect time to have a go at a job like this but make sure to have plenty of axle stands and other objects under the car to avoid crushing yourself because you'll be spending a lot of time flat on your back completely under the car.
I really didn't take good notes when doing the job but the only tools you need outside of the usual socket set would be a stubby 22mm ratchet spanner, there is a special BMW tool for removing the O2 sensors but I managed by using a stubby spanner. You also need a 13mm socket on a long extension to get to the clamp from the top, I have a couple of 1/4" socket sets and had to use all 3 extension bars to get it far enough.
keving1 said:R.E92 said:I didn't drop the subframe but it may have saved me time and skin. I just unbolted the steering rack and moved it forward (just 2 bolts)
Thanks for the advice R.E92 it has been helpful, did you remove both the front sensors before removing the downpipe and did you replace the gaskets on the turbo to downpipe joints or leave the existing ones in place?
Other things have got in the way over the last week so I haven't been able to do anymore on this but hopefully will have a full day tomorrow to crack on with it.
It took me quite a few hours over 2 days but all the help on here got me throughR.E92 said:How did you get on?
keving1 said:It took me quite a few hours over 2 days but all the help on here got me throughR.E92 said:How did you get on?![]()
I eventually moved the steering rack forward and removed the small heat shield over the bottom of the steering column. The removal of this shield allows far better access and was now able to get a hand in and up either side of the downpipes.
Also took both downpipes out complete with Lambda sensors as the first one I tried to remove was stuck fast. Fairly easy to manuver these in & out and the sensor came out with a sensor wrench.
Taking them off took longer than getting it all back together as the learning going through the process makes it a lot easier and quicker. I reckon I could now do the whole thing in 4 hours or less![]()
On to the next jobs - intake valves cleaning & fitting H&R front and rear anti roll bars when I get them.
