z4lincs said:So small its nothing to worry about? worth a weld? or beyond repair?
Don't think there is a cracked wheel that is nothing to worry about TBH.
If left it will get worse...and once past the bead on the tyre will lose air. It is structurally compromised, even with a small hairline crack.
It can be welded legally in the UK, but will weaken the area around it by the welding process.
I certainly couldn't live with a cracked wheel, it would worry the shite out of me and I would be taking the wheels off every 5 minutes to check it hadn't got worse. I would also never have a wheel welded. But each to their own, as the saying goes.
Pondrew said:z4lincs said:So small its nothing to worry about? worth a weld? or beyond repair?
Aah, you wuss!![]()
matsmith749 said:this is the smallest alloy crack I have seen TBH.
Stevo1987 said:Tyres plus have someone who welds wheels.
50 quid a go I think.
Fady said:Thought it would be relatively easy to source some secondhand undamaged rears to give myself the option of returning to stock, but is not proving to be the case.
z4lincs said:matsmith749 said:this is the smallest alloy crack I have seen TBH.
Good to know at least!
john-e89 said::lol: How many has he seen, do you know…? Could be 2![]()
john-e89 said:Welding alloy wheels is temporary, you weaken the surrounding alloy giving that area an excuse to crack more than when it was new, and a small crack now is only going one way….they don’t heal themselves. Hey, up to you, if you want potentially and very likely more issues then weld them, you’re a victim of crap wheel manufacture as lots of E89 owners are but welding them isn’t the way to deal with it.
z4lincs said:john-e89 said::lol: How many has he seen, do you know…? Could be 2![]()
Yeah I won’t be just leaving it, fear not!
I think I’ll spend a bit of time seeing if I can source a good replacement, or yeah, maybe a full new set of something else may have to be on the cards. Def prefer the OEM look however
matsmith749 said:Is it really a BMW thing?
The trend for bigger & bigger wheel diameters, also being lighter & lighter with tiny thin tyres is common across all manufacturers TBH. All are seeing the same kind of issues with wheel damage, especially when used anywhere with less than perfect road conditions (ahem .... UK).
Runflat (ie hard sidewall) tyres just makes the problem more likely.
I doubt the alloy quality is worse for BMW branded wheels than any other similar marque.
Also, with regard to the efficacy of a weld on a wheel crack - I don't know the truth about this (does anyone?).
It feels like it makes sense that it could weaken the wheel long term - but is that just old wives bollox? Welding has been used in construction & repairs for many years, and thousands upon thousands of wheels.
Do they actually break easier afterwards? I'd love to know for real (not just gossip)
