325mm brake conversion front backing plates
Robster68
Looking to replace shot 3.0l front backing plates with new 3.0si 325mm version for future brake upgrade,I’m assuming this still works a with 300mm set up until time come to replace.I’m using standard 108 18” rims.
bigwinn said:
It does- I can confirm I’ve done this and it’s coolio
Thanks,will order tomorrow from bmw Toulouse,
on bmwautodalys.it website 325mm version is less expensive than 300mm replacement 👍
Be careful there, to change the plates the hub has to be removed which could mean new bearings! Quite costly as i found out recently. :roll:
It’s a bit late for that mate 😂
Everything is being replaced,so no worries there
