With this drop do you need to change anything other than the springs. Do you need dampers too? Does the camber need changeing? Are there any issues with comfort and speed bumps? Sorry bit of a newb question.
jan_tekin said:If its the Eibachs it would be 15mm drop, Shocks should be ok, but an alignment would be required and speed bumps will be more of an issue![]()
