Stevepj said:Stevepj
I'd be worried about that too. Has it been shunted? Chasis bent?
You could buy it and get the ABS fixed along with everything else it needs then sell it for around £3 - £5k so might actually be worth looking at!
Will be interesting to see what it goes for. Doesn't look well-loved but cheap.skelters said:Around 6 hours left on the eBay for this car.
Stevepj said:Rather than worry about which engine is better I'd be more concerned about how and why both lower rear suspension arms got so badly damaged they needed replacing at MOT a couple of years ago - rear end shunt maybe?
skelters said:Maybe someone close by can take you out or let you try the 3.0 SE or the 3.0 SI.
I had the 2.5 and knew as soon as it went that the next Z4 would be the 3.0 SI.
Just do it as you will not regret it. *
You had the 2,5. 177hp?
I tried all three 2,5’s, and both 3 liters, and ended up buying the 2,5 218hp version, because its the most revy and sporty of the lot.
* Unless you buy a lemon!
Martin Knud said:skelters said:Maybe someone close by can take you out or let you try the 3.0 SE or the 3.0 SI.
Capa said:Is that *aaaaactually* that cheap?
