So why does it run perfectly when you reset it? Sounds much more electrical and less basic physics to me?Chris_D said:it's the ccv diaphragm. am tellin ye.
Idk. Maybe like how my knackered throttlebody would work fine when you reset it. Then on the next startup it would go kerplup and die.enuff_zed said:So why does it run perfectly when you reset it? Sounds much more electrical and less basic physics to me?Chris_D said:it's the ccv diaphragm. am tellin ye.
Worth a look at leastChris_D said:Idk. Maybe like how my knackered throttlebody would work fine when you reset it. Then on the next startup it would go kerplup and die.enuff_zed said:So why does it run perfectly when you reset it? Sounds much more electrical and less basic physics to me?Chris_D said:it's the ccv diaphragm. am tellin ye.
Dont forget that a lot of components work fine outside of operational parameters/limits set by the dme.
Still only Monday in Norfolk mate!Rix said:How did the reflash go? Any joy?
Cheers.IRD said:Martin/Stuart et al. I really enjoy reading the posts. I just wish I understood what they were all about, especially all those acronyms. I hope Wednesday is a better day weather wise than today and that all goes well.![]()
Thanks Martin. Every day is a school day. Joking apart. It is impressive to see the range of knowledge and expertise available on the Forum. Imagine what the cost would be if you had seek help from a main dealer.enuff_zed said:Cheers.IRD said:Martin/Stuart et al. I really enjoy reading the posts. I just wish I understood what they were all about, especially all those acronyms. I hope Wednesday is a better day weather wise than today and that all goes well.![]()
Acronym is easy. DME is the ECU for the engine. :roll:
More cost and probably less ideaIRD said:Thanks Martin. Every day is a school day. Joking apart. It is impressive to see the range of knowledge and expertise available on the Forum. Imagine what the cost would be if you had seek help from a main dealer.enuff_zed said:Cheers.IRD said:Martin/Stuart et al. I really enjoy reading the posts. I just wish I understood what they were all about, especially all those acronyms. I hope Wednesday is a better day weather wise than today and that all goes well.![]()
Not yet, but why would that reset when I clear the codes? And we can hear the pump running too.Chris_D said:Before you quit, like a big fat quitter eating a melted slice of quit, have you tried swapping/replacing the fuel pump relay?
Who knows?enuff_zed said:Not yet, but why would that reset when I clear the codes? And we can hear the pump running too.Chris_D said:Before you quit, like a big fat quitter eating a melted slice of quit, have you tried swapping/replacing the fuel pump relay?
Never rule anything out.Chris_D said:Who knows?enuff_zed said:Not yet, but why would that reset when I clear the codes? And we can hear the pump running too.Chris_D said:Before you quit, like a big fat quitter eating a melted slice of quit, have you tried swapping/replacing the fuel pump relay?
But it's worth a look and easy enough to check isn't it?
enuff_zed said:Well I have bad news dammit!
Despite Stuart's best endeavours we cannot fix this motor.
I managed to reproduce the fact that it runs perfectly for a few seconds when you reset the faults and we are in full agreement that it is the DME. Cannot feasibly be a mechanical problem or why would it run so cleanly when you reset the electrical gubbins?
However, INPA could not even see the DME, let alone find out its software version or attempt a reflash. As far as it was concerned there was no DME in the car!
Interestingly, while we tinkering around, every minute or two we heard a click from somewhere in the locality of the DME and the fuel pump would run for a couple of seconds.
Anyway, I have invested a fair bit of time and materials into this car now so I'm not willing to break it just yet.
Next step is get the DME out and send it off to either be repaired or cloned.
Watch this space.
Sent a few queries to some of the companies that advertise repairs etc. I'll see what comes back.Rix said:enuff_zed said:Well I have bad news dammit!
Watch this space.
Thanks for the update - disappointing but another bit of investigating compete. Weirdly I have the same issue insofar as my cheap code reader cannot see the DME and wondering whether to get mine sent away. I opened mine up at the weekend and couldn't see anything physically damaged in it. I multimeter tested the mosfets which seemed ok but that was the end of my technical skills! Have you got somewhere in mind for where to try to get it repaired? https://www.actronics.co.uk/ get recommended on the UK salvage YT channel but they seem to only deal with the trade.
