Got a problem with this 3.0i that I'm trying to get through an MOT.
It has been sat for round a month without being started.
New battery, and yes my first action has been to put it on charge again overnight, just in case.
Symptoms:
1. Car starts first turn of the key, every time.
2. Sounds like it is running on about 3 cylinders and hunts around 500 to 1500 rpm
3. After about 30 seconds it gives up and dies
4. Repeats this as many times as you like, with no differences.
5. EML and engine light on
6. Traction control light on (which I believe is as a result of the engine issues)
7. If I do a fault reset with the engine running it immediately runs perfectly, for about 10 seconds, then reverts to hunting and eventually dying. This seems to possibly be as it is doing some kind of self test, and once it finds something not working it then throws faults and hunts again.
There are NO codes for misfires on any cylinders or for any O2 sensors.
I initially had these codes in the Engine Management section:
2830 DME self-test: checksum
2796 Throttle: adaptation values incorrect
28B2 Speed limitation: reset
I carried out the throttle adaptation reset, both with the Autophix and the manual way, holding the pedal down, ignition on, then off, etc.
Now, after discovering that I can get it to run cleanly if I reset while it is running I have these three codes:
2796 Throttle actuator-test, lower stop
I've been googling and scaring myself with stories of dead DMEs.
Anyone got any thoughts, or come across this before?
Symptoms:
