Ed Doe said:1. Simple mathematics dictates that reducing the final drive multiplies the torque to the road by the same factor, so yes it is literally a bolt on power adder - available torque at the wheels is higher. HOWEVER, as has already been said, a shorter final drive will result in very short gears, and ultimately higher rpms for the same speed in 6th gear. So there is room to modify it a bit, and you'll get a noticeable benefit in that the gears will be more closely stacked so you'll be in the powerband all the time, but if you go too mad you'll end up buzzing about at 5k rpm in 6th doing 60mpg (I exaggerate but you get the point).
You only get more wheeltorque as long as you're in the same gear. Reducing the final drive ratio will make the gears shorter. The part of the acceleration where you need to upshift earlier you'll be slower until the point where you would be upshifting with the longer final drive gear, at which point the shorter gear will be faster again. So there only is a partial benefit along the acceleration line. A 0-62mph time could even get slower :wink:
Its not a bolt on power adder, as there is literally no power added. The power output stays the same from the engine.
As for using the z4m diff, you need the complete rear axle including trailing arms brakes etc as the driveshafts wont fit the wheelbearings or hub flange.
And you may need the propshaft too (I dont know if you can get away with swapping the propshaft flange, if its compatible)
