3.0 replacement exhaust tips
maxman said:
Try Sopers of Lincoln.They where available not so long ago,cost was about £60.
I think the 3.0 is different to the 2.0,2.5 ask Jamie at Sopers he is a top bloke.
I was on to them today to order a clear 3rd brake light and Mark told me that Jay had left. Mark seems like a good guy, fwiw.
Dude, that's not an oval. That's a circular exhaust slash cut.
Oval:
You're going to make me go outside and take a picture of mine aren't you... :roll:
I'm going to order some new ones this weekend and then I'll remove mine and hopefully clean them up to sell on if they're not too far gone.
Had never heard the term "slash cut" before, so if that's what you call them, fine. Must be because we've never used that description on this side of the pond. :D
So we'll agree on squashed oval :wink: . Bottom line, those X5 tips still won't fit...
LOL! Damn foreigners ;)
They can't be oval in anyway, an oval is a squashed circle, right? So the pipe on the 3.0 exhaust is a perfect circle, it's a perfectly round tube (not oval), but the end is cut at an angle (or slash cut) to create a longer look. Much like when you cut a baguette at an angle to get a larger surface area from it.
Why won't the x5 tips fit? Are they too skinny where they bolt to the "dirty exhaust" underneath?
The trouble is that the pipe the tip fits to is oval. And yes it can all be done but it all at a cost with extra machining time and multiple set up.
I would have to make an oval piece to fit to the pipe. Then make the round part sepratly. The round part would then have to be set up in another machine to put the angle on. Then i would have to tack weld the 2 bits together then fabricate 2 bits to fill the sections betwine the oval and round part. then seem weld it all together. Its all possible but that's about a days work.
What i did with mine was to cut the ovals off all together and the just have 2 round pipes but at staggered lengths. But then i was able to weld the new tips directly to the back box.
Note the drivers side was not in its correct position. It is now i just don't have pictures.
If it's that much work I'll just pay £38 quid for a new set of BMW ones dude.
I thought you could have got away with doing both ends round, (obviously on the car end it'd have to be the size of the larger part of the oval, then having the grub screw going through the bottom to secure the circle to the oval in a solid manner?
Your exhaust looks bloody excellent though, really very jealous. Wish I had some skills valuable to you so we could trade time ;)
P.s when (not if) I come to you for this brake adaption I want doing, I'll bring my camera and tri-pod and take some real pictures of all your hard work (your car and items you make)
To be honest it would be loads cheaper.
If its just that they are dirty take them off send the to me and i can polish them up. You will probably be very surprised how clean they will be when you get them back.
See my edit above btw...
I'm going to remove this weekend and have a crack at polishing with what I've got. If I don't get anywhere, off to you they shall go :D
Its mega easy for me as i have a polishing mop at work. Its only a few minutes work. So if you don't get on well i am more than happy to do them for you. As i have said to others no charge just pay the postage. And if your happy make a donation to the forum.
Now that is a generous gesture. What a top man, MM is.
