Boyo said:I like those exhaust tips - I have always been underwhelmed by the factory ones on my 35is. Could I ask where you got them and the tightening collars.
Me too, they've bugged me for ages now, you just can't clean them up at all & I prefer the polished look. TRP Performance in Walsall Wood, my local independent that I use for the more menial servicing tasks. I took it there for the brake fluid change, but they also do tyres, custom exhausts, mapping and dyno sessions as well as servicing. I'm sure any custom exhaust specialist near you should be able to do the same and supply the collars too. They're 3.5" (89mm) diameter short trims, I really wanted the "Jet style" trim rather than the rolled edge but they only had those available in the longer length. They would have stuck out too far from the valance due to only being able to cut the existing pipe just in front of the exhaust flap bypass section. They offered to order the shorter version in but I wanted it doing there and then! :wink:
If I end up keeping the car I can always change them at a later date for a different size or style without all the hassle of grinding away welds and re-welding
