bimersmile said:A known design fault on the z4 is that the roof motors often need replacing due to drainage channels being blocked through poor design. I found out the hard (expemnsive) way. Its totally preventable if they are nt regularly cleaned to keep clear but mention it here in case it helps anyone else.
BMW Stealership wanted to charge £1,350.00 but the independant BWM specialists, Beckett Motors in West Sussex has one of BMW Chamdlers ex Technicians working for them and they will do the same job for half the price with same gaurantee. I've had no probelsm since. Worth bearing in mind![]()
flybobbie said:Seems a lot of problems with roof sensors. Would be nice to know if there is a trend towards one particular switch.
Would be nice to buy one in, just in case![]()
I can see where the hood down mechanical limit switch is and would suspect that could cause problems.
cliford said:Tried it on my 2014 BMW 328 and worked like a charm. Thank you for saving me a trip to the dealership.
