2009-2013 side marker lights upgradable to 2014-2016...?
polo1
Are the "older-style" white square side marker/turning signal lights on the 2009-2013 Z4 up-gradable to the new 2014-2016 ones...?
Thanks!
The older-style square one looked like it took up more room - and was concerned that there would be markings under it that would not be covered up by the newer-style.
polo1 said:
That's really the only stylistic change on the 2009-2016 models, correct?
Pretty much, I think later cars have LED halos but I am not sure.
The indicator upgrade is super easy, takes maybe 15-20 min tops. Once you pop the old ones out just wipe the paintwork underneath with a wet cloth before you pop the new ones in.
I have seen them replaced on Youtube and there was a reference to clipping a small plastic lug off the new lights because there isn't a hole for the lug in the body work of the older car. Other than that straight forward swap. From memory the lug is approx half way along the new light fitting and would simply act as a support for the longer extension piece. If you are concerned about rattling or similar then maybe a small piece of double sided tape will do the job.
Smartbear said:
The headlights themselves are different but the shape is the same :thumbsup:
Ah... is that why they look brighter and "nicer"...?
Did those change in 2014 also...?
There is a new video on YouTube that shows you clearly how to change the indicators, might be helpful:
[youtube]TY52q0nVP0c[/youtube]
Lci bought the changes in late 2013 :thumbsup:
Tsk tsk SmartBear...the press releases were dated December 2012 and quoted customer deliveries Spring 2013.. :thumbsup: :rofl:
He was giving me the fear using that Stanley knife - just waiting for it to slip towards his hand
Smartbear said:
Everyday’s a school day :P
Please pay attention in future! :tumbleweed:
Listen carefully I shall say this only one! :rofl:
:rofl: I don't remember using any knife and just bent it back and forth a little and it broke clean off.
