2007 z4 3.0si handbrake light
Yeats
New member
Hi - I hope someone can help - I had 3 lights appear in December - diagnosed as DSC issues .. sent unit off for refurb - refitted and all seemed ok . Now I have a single light back in - the handbrake amber . It only comes on about 20 minutes after starting from cold ? Any ideas and suggestions gratefully received - thanks
I think that's usually related to brake fluid level. I'd place a good bet it's a bit on the low side if you have had the ABS unit out. Top it up and you are probably good to go. Keep your eye on it in case you have a fluid leak anywhere. :thumbsup:
