2006 Z4 3.0si Coupe E86 Wheel Tyre Newbie query
Beemer233
 Kalamata, Greece
Hello....recently joined newbie owner here .....I have used the search facility for offset/wheel/tyre size suitability but am still unsure...can anyone please comment on the following alternative aftermarket fully refurbished wheels in gloss black that I have sourced and suitable tyre sections/profiles etc ...car is currently on silver 18 inch 'Borbets' 225 F/245 R with M option suspension etc....
Stud Diameter: 120 Manufacturer Part Number: MV2 STYLE
Rim Structure: One Piece Rim Width: Front 8 J Rear 8 J
Number of Studs: 5 Rim Material: Alloy
Surface Finish: Powder Coated Gloss Black Rim Diameter: 18
Reference OE/OEM Number: 36117896470 M double spoke 135 Offset: Front 47 Rear 47
EAN: Does not apply
Many thanks in advance......
Hello and welcome, yes they'll fit fine as they are from an e46 3 series, which are a very similar platform and share brakes and engines with the e85/6, I believe some 3.0si came with MV2s or 3s.
For reference the 3.0si sport came with 18s, 8in et47 front and 8.5in et50 rear, so if you stay near those measurements and on standard suspension you'll be fine.
Brilliant news.....thank you very much indeed...no lowering will be taking place....I need ground clearance here in Greece!.....maybe new rear springs/shocks when the time comes...the existing 'Borbets' look similar in many ways....I believe they manufacture many OE wheels for manufacturers including BMW...
