Hi all, first post here. Always wanted a Z4 and bought myself one this past week. Love the style of it and definitely wanting to keep it! However its throwing some issues at me that I need help identifying what to get fixed or replaced.
When I bought it, took it for a test drive with the owner for a while and everything seemed great. Got it home and drove it for a couple of days on short journeys, no issues. But, after a long drive and then stopping at a friends, upon restarting with a warm engine, it immediately went into limp mode. EML light and Exhaust light on dash in yellow. I got a basic code reader on it and it gave codes P1050 and P1062. I cleared the codes in the morning and again from cold start seemed fine. But after another longish drive the same thing happened, Limp mode, EML and exhaust light, P1050 and P1062. I also noticed the idle was getting slightly rougher.
I spoke to the previous owner who advised me he had cleaned the vanos solenoids but also had a new one in the boot that he'd bought just in case, but ended up just cleaning them and they were fine, I could replace one of them at least. So I replaced the one on the exhaust valve as I had the exhaust light up. Followed a guide ensuring all done correctly with seals etc. During this I also noticed that there was some oil in the exhaust solenoid connection which I cleaned out, which hasnt returned since, the oring on the replaced solenoid had a slight nick in it so I was thinking that was the issue.
But again, after long journey same thing. Also idle getting rougher. I then decided to switch the solenoids around to see if the issue moved away from the exhaust light at least. But after switching, the rough idle has got a lot rougher and worries me that its going to die although it hasnt yet, also now noticing on set off that it seems to be spluttering a little when initially putting revs on. After getting home from work today, EML light and limp mode, and also a new code thrown up p0012 Camshaft Position “A” - Timing Over-Retarded (Bank 1).
Cleared the codes again and started cold, no warning lights but that rough idle and splutter is still there.
So thats where I am right now. Just looking for advice on what to ask a mechanic to look at and/or what to buy as a preemptive replacement part to try solve this issue. Its a lovely car and I dont mind throwing a little money at it to get it to a place where I feel I can trust it not to die on me. Also, I want to enjoy it not worry about it.
At this stage, my thoughts are to:
Get a new VVT Actuator Motor
OEN 11 37 7 509 295 — BMW
OEN 11 37 7 548 387 — BMW
OEN 7 509 295 — BMW
OEN 7 548 387 — BMW
and possible a new Eccentric Cam shaft sensor
OEN 11 37 7 506 503 — BMW
OEN 11 37 7 513 783 — BMW
OEN 11 37 7 527 016 — BMW
OEN 7506503 — BMW
OEN 7513783 — BMW
OEN 7527016 — BMW
Everything else on the car is fine and i'm seriously in love with it. I'm based in South Yorkshire if theres anyone around this way who has a better reader to diagnose
Thanks all
OEN 7 509 295 — BMW
OEN 7 548 387 — BMW
OEN 7506503 — BMW
OEN 7513783 — BMW
OEN 7527016 — BMW
Thanks all
