SystemLord0
Hi everyone;
I have a 2003 Z4 3.0 120,000 miles with no engine modifications and it runs great and drives great but due to a code i have not been able to pass smog the past year so it’s been sitting. I am worried that if i don’t drive it soon it will be a slow and quite death.
I have always had some issues with an Trouble code popping up randomly (P1515) but until 2 years ago i was able to clear the code and it would not come back for a few month so i could pass smog. Now the code comes back at as soon as the car is ready to smog and it trips the engine light meaning i can’t pass smog in California. All smog values look good.
Initially in 2012 my shop came up with the following:
P1515, Electronic Throttle Position
But back then it only showed once in a while and they could not locate the exact issue.
They also came back with a engine code “RAN BMW CODE 2774 though BMW which came back as E53 X5 ERROR in INST. CLUSTER”. which stumped us.
Flash forward 2-3 years i even went to BMW to have them pull the code and tell me what might have to be done to get it fixed. They were not very helpful and told me it’s an electrical issue and I have to replace the instrument cluster…. I sad thank you and left.
Made it a couple of years longer all the way to 2018 but now the code is coming back so fast/repeatedly that when I get close to all my sensors ready for smog (from cleaning codes) the P1515 flips from pending to engine light on so that I can’t pass smog.
Some online searches come back saying that P1515 is related to electrical “over current” detection but it’s also very vague.
So far I have replaced the accelerator pedal (code still coming), found a leaking hose from the air blower to the engine, Inspected the DISA valve but it looked very clean and solid so I did not replace it.
My next plan was to inspect/replace the throttle body and go over all the air intake hoses one more time.
I am hoping someone has some pointers of what I should look at next or try so I can start going down some kind of systematic list.
I have been using BlueDrive on the OBDII to get my data and i have been getting the P1515 pending trouble code and engine code 2774 (Engine cut off time) and 27A4 (Interface EWS 3.3 - DME).
P1515 stays as pending for a while before setting off the engine light.
Any help would be much appreciated!
Manuel
Manuel
