2003 z4 2.5 traction control, tire pressure and brake light indication
Jeremy Z4
New member
 Puerto Rico
Hello everyone, 2 weeks ago I disassembled my whole rear subframe and installed all the bushings. When i reassembled al was running fine, but the traction control, brake, and tire pressure lights stayed on. Whent to autozone and the scanners did not read the error. Any advice on where i should start or common causes for this to be on?
I would start with the rear abs sensors.
If the speedo is working then the left one is ok.
[ref]enuff_zed[/ref], speed sensor seem to be working fine, i mean the car is reading actual speed. Brake pads could be at a 70% dont thing that could be the proble. Im waiting for my mecanic to arrive from vacation to read with his scanner wich will be until next monday and really dont know what could be wrong
Sorry I didn’t make myself clear. Every wheel has an abs sensor and if one fails you can get those lights.
But the rear left one also sends a signal to the speedo, so if the speedo works then the left one must be ok.
