zombie804life
New member
Good evening everyone,
I have a 2003 BMW Z4 2.5 M54 E85 5Speed Manual. I had problems with misfiring and problems with the disa valve and maf sensor, and the lower intake boot for the throttle body was torn up. I replaced all of those parts at once. Then I replaced all o2 sensors(except one), coil packs, and spark plugs(within a week). I left one of the old sensors because I could not get it loose ( I am spraying pb blaster on it to hopefully get it out tonight if it stops raining long enough). I ran up all the codes cleared its self. I was super excited to drive my car after it was garaged for a hot minute. It sounds sooo great. It has never sounded that great since I owned it. its driving well misfiring is gone... WELLLLLL, however, driving home after all the fun, the maintenance light came back on. I got some new codes that popped up, not too sure what to do.
Everything in this car is self-taught. Any help would be great!!!! This car is my baby/ project car! HELP ME GET IT RUNNING
ID | Description
281D | DME: BSD generator: signal
2869 | DME: DME self-test: RAM check Faulty
299F | DME: Oxygen sensor after cat conv.. bank 1 :signal
next category IN SCANER
ID | Description
5D8C | ABS-DSC: DSC sensor CAN timeout
5D8F | ABS-DSC: sensor fault, internal
5E30 | ABS-DSC: Transverse acceleration sensor
5E385 | ABS-DSC: Rotation rate sensor
ID | Description
611D | EPS: Power supply
ID | Description
0F | IHKA: AUC SENSOR
ID | Description
02 | RAD: Fault in aerial supply
ID | Description
40 | RLS: Optical initialization
ID | Description
93E7 | sim: undervoltage
ID | Description
05 | SZM: UNDERVOLTAGE, SEAT HEATING
this is the least amount of codes i had on this car by the way.
all my parts are bought for FCPEuro.com and amazon.
so far I had replaced:
Lower control arm bushings (amazon)
control valve gasket (amazon)
valve cover grommet set (amazon)
water pump (amazon)
Thermostat (amazon)
Disa valve (fcpeuro)
lower intake boot to throttle body (amazon)
maf sensor (mass airflow sensor(fcpeuro)
oxygen sensors x4 (fcpeuro)
coil packs (fcpeuro)
ID | Description
ID | Description
ID | Description
ID | Description
ID | Description
ID | Description
ID | Description
ID | Description
water pump (amazon)
Thermostat (amazon)
