Hi got this problem with srs light not coming on with ignition on,I have some fault codes so I recon light should be permanently on also e few years back there was a failure at mot for airbag light on OK on retest and I know some mot stations used to disconnect light or blank it off.Idid a test using diagnostics to check clock and lights and srs light did not come on so removed clocks thinking its a bulb removed but looks like a sealed unit also checked module at rear of handbrake for disconnected wires but all OK anyone got any ideas thanks. Iain
