özgür evren
Hi, I recently got a Z4 2003 3.0i with M54 engine and yesterday I have removed the DISA valve for a check if it is loose and needs replacement. DISA valve seems OK but I could not be sure the condition of it. Photos are attached.
There is quite amount of oil residue on the valve flap and the air intake itself.
Looking at the photos, your experience and opinions are much appreciated:
1-) Should I change the o-ring seal around the base of the DISA valve flap?
2-) Is this sticking oil residue normal? If not normal, where should I look?
Thank you
Thank you
