2003 2.5i Sound Generator
Z44Jon
What do I need to fit a sound generator from a 3.0i to my 2003 2.5i M52 auto please?
Any suggestions where to get it from other than BMW too?
You may be missing a mounting and clip that go under it and onto the head? You will also need an inlet elbow pipe from a 3.0i and to swap the sleeve between that and the pipe from the MAF as they are slightly different diameters.
Edit, looks like the4clip is there, so check out realoem and you'll see the mounting bit you need too.
