patriot66 said:
Thanks mate, well, as I said, maybe (on reading other thread), colb said: Faulty Maf, not registering the correct amount of air passing into the throttle body, if its over reporting the ECU will see this as a lean mixture much the same as extra air from holes or splits as in No.1.
And maybe now everything will settle with OEM air filter, as MAF will register the
Smartbear said:
A worn out vanos will reduce the low end torque of the engine but i can’t see how it could lead to oil consumption issues. Have you got a link which details this?
correct amount of air (with high flow Pipercross the measurements were bad maybe).
I can't find the link now, but some US forum about M54B25 engines. Also, here are the common two fixes - https://www.zroadster.net/forum/viewtopic.php?t=45716
Has anyone tried 02Pilot Mod ?
Also,
patriot66 said:
you did the Vanos yourself? Is this what I need? https://www.ebay.de/itm/Premium-Reparatur-Satz-Vanos-fur-BMW-Doppelvanos-Dichtsatz-M54-M52-TU-E46-E60-X5/192663021249
How did you do it? Is it manageable without the garage?
Thanks!
