Hi all my 2003 3.0l has two intermittent issues that I can't work out.
1. Every now and again when I have first started the car in the morning as I pull away the car sounds like it stutters but then instantly clears up and drives as normal? I thought coil pack degrading possibly but there are no codes and no other signs of a fault.
2. Since buying the car in June on three occasions it hasn't started when I turned the key, turned over as normal but no start, second attempt it starts instantly. Again no codes and drives fine, this has only happened with my keys though not with my Mrs set, this may be coincidence but wondering if my key may be going flat and causing this?
Any thoughts? Thanks in advance.
