2 issues in 1 night!
Driving the 25 mile drive back from visiting my parents this eve, I found 2 issues....sighhh!
Firstly - a red exclamation with brackets and dotted lines, which suggests a flat tyre of run flat sensor issue. I don't use RFT, but never had a error. Tyre pressures were fine all round.
Secondly - 2 weeks past my oil change, and this is the first trip long enough to have my oil level show. Shows I'm midway between max and min, which I believe equates to a half litre? I know it showed full after I did the change after a quick warm up - could this just be it settling? Filter and filler cap look fine - can't get under the car due to the bloomin' rain.
Any ideas to both guys and gals? Any advice would be appreciated!
First issue, likely crap on a sensor which may clear on its own.
Second issue yes after running the engine the oil level will reduce. Top it up with a very small amount so that you don't overfill and monitor it over several days and weeks.
I suspect all is fine.
Cheers Maniac, and you were correct!
Suspect my tyres were due to diving the bumpy, muddy country roads - reset the error and it didn't come back.
Oil hasn't shifted since so defo not any sudden loss so must have been it settling. Panic over nout as per always! :)
