WANTED 2.2i flywheel
Wanted
Joez4
 West Midlands
Hi all I'm after a daul mass flywheel for a 2.2i wondering if anyone has one going spare that they never got round to fitting.
Will even consider a low mileage used one if any of the resident breakers have one?
Turns out the flywheel for some reason is unique to the 2.2 z4, even the 2.2s in the e46s use a different flywheel, and the 2.5 z4 uses a different flywheel even tho both engines have the same 5 speed gearbox.
They all appear to have the same clutch tho,
The frustrating bit is it looks like Luk have stopped production of the flywheel for the 2.2 and I can only find a genuine example at over £1200, which is probably the value of the car.
And I thought it would be the lack of airbag modules that would end up scrapping my car in the future.
Please do more research, as I might be missing something, but realoem lists the same flywheel for the 2.2 and 2.5?
Again, please research this further before buying anything, but at a glance, you have options
From my research on realoem the flywheel for the 2.2 also fits the 2.5 but all other parts suppliers say the 2.5 has a separate flywheel that apparently is not compatible with the 2.2 but appears to fit the 3.0
It makes no sense to me why the 2.2 for the z4 would have is own flywheel that fits no other m54 engine but from what I have researched that appears to be the case.
2.2 flywheel
21217519493
luk part numbers
2.2/ 415019010
2.5/ 415018910
