Fulhamsteve
Hello all.
Quite confused by the problem my e85 has started suffering from over the past few days.
When the temperature outside is warm and its dry, the car runs the same as it ever did. However, if I start it first thing in the morning, when it's cold and damp, it won't idle properly, fluctuating rapidly between about 500-2000rpm and shaking violently for a few seconds before stalling. It starts heartily and idles fine for about 20 seconds before starting this behaviour. I don't know if it was coincidence but it seemed to start the first time when I turned my blowers on full to demist the screen. It seems to correct itself if I unplug the MAF.
What are we thinking? I have so far checked for vacuum leaks (would have to be massive to cause this I'd have thought), cleaned the IAC valve and cleaned the MAF sensor. Nothing looks too abnormal from the live data I've seen, fuel trims are fine and the MAF is reading normally. The battery voltage was a little low (12.2v) but rises to 14.5v when running, so the alternator is fine. Both o2 sensors are behaving normally. DISA valve was rebuilt about a month ago and the car has not displayed any DISA related symptoms since it was rebuilt.
