Finally got around to sorting the cracked exhaust manifold on the 2.0l I bought a couple of months ago. Didn't hear it blowing when I viewed and test drove it but it had been out and about before the viewing. Post purchase I noticed the blow on cold starts but it went after the exhaust heated up. Couldn't see the crack but diagnosed it as cracked and started getting some parts and a replacement manifold that wasn't cracked. Spent my Sunday stripping it out after the under trays were removed. The exhaust downpipe joint studs and nuts were just the same nightmare to get out as I went through on my previous 2.5. Had to resort to the angle grinder with a cutting disc to slot the flanges to release the pressure on the splined studs and air hammer them out once their rusty nuts were also cut off. A couple of exhaust brackets unbolted and the rear section was pushed back out of the way only a short distance. Attention then to the top and all the copper manifold nuts were removed using a 11mm short and long socket. Had to remove the steering shaft which was easy to do, just unbolt top and bottom UJ joints, pull the bolts and the shaft drops down from the top and is easy to lift it off the bottom rack spline. Once that's out of the way the manifold can be pulled off the studs and lowered down and off the car. Fitting the replacement with new gaskets top and bottom and new copper nuts, Replaced the down pipe studs with stainless nuts and bolts.
All this done on my scissor lift but took me all day 10am to 8pm and have to finish off tomorrow, few more brackets and fit all the new exhaust sensors I am treating it to. The time consuming bit is those downpipe studs and nuts and the multitude of manifold nuts at the top.
