Hello all,
I was wondering if anyone will PLEASE be able to give me some advice on my issue. - my car is a 2007 e85 2.0
I have experienced a lumpy idle from when i first bought the car back in 2020, but after going back to the dealership to find it had an air leak from the air filter pipes amd these being replaced, it did run slightly smoother but there was still that slight hesitation. Just last year i replaced the VVT Motor and reset all adaptions as this had failed. Yet i still had a slightly lumpy idle/hesitation. which leads me to the issue i have been having over winter, which has got progressively worse.
So upon startup during the winter months on cold mornings/evenings i would receive a flashing engine light when setting off to/from work. This always happens under load, but then continued to disappear after about 20 seconds or so of driving. this has now got to the point where i will have a solid engine light constantly on as the car cleary is misfiring, and continues to bring back up the same fault as read below.
After plugging in the the diagnostic kit i receive these codes.
29CC - Combustion Misfire on several Cylinders.
29CE - Misfire Detection Cylinder 2 In 4 Ignition Sequence
I have now tested all 4 coils and even tried a new coil just to see if i can get the misfire to follow a certain cylinder. I have done the same process with the spark plugs amd have now even replaced all 4 spark plugs just to eliminate them from the test. ( I really am trying not to throw money/parts at it, so thought the best place to go next was here.
After researching and reading some posts it looks like the vanos solenoids can cause similar/ the same issues i am having. is it worth trying to replace them next? I would really appreciate any help on the matter. (p.s sorry for the long read) but thought it best to explain my whole process of owing the car. Thanks
