1st to 2nd gear change
Jcm325
I seem to be having trouble with the transition from 1st to 2nd gear , sometimes it's nice and smooth but other times it's a bit lumpy?
A bit of research points to the clutch delay valve but then other posts say it makes no difference
Anyone else have similar?
E85 m54 3.0
The stormwerks gear knob I bought from enuf zed has improved things but still not perfect
My 2.2 has a 5 speed and has the same problem. I found that I have to be quick and positive with it otherwise it seems to be notchy.
The CDV was included for the US market to protect the drivetrain against improper dumping of the clutch by drivers who weren’t used to driving a manual. For most manual drivers, removing the CDV does make it easier to change gear better, particularly first to second. Some people claim there is little benefit, but no-one thinks it makes the gear change worse. It’s also very simple and cheap to remove, so why not?
I've had the CDV removed on 4 or 5 BMWs and it improved all of them.
Fresh gearbox fluid helped too, despite BMW claiming they were sealed for life!
Most people report improvement in shift feel with CDV removal in non-M variants. I found minimal difference in my ///M, but my gearbox is not as obstructive as that in some other ///Ms, being only a little stiff when cold.
As Mr T has said, fresh fluid helps too.
The cdv makes it feel like the clutch is slipping when you’re trying to drive fast. I guess it is like letting out the clutch very slowly so it is slipping a bit. Removing it does make it feel better but I have found it to be a little clunky occasionally and have kangarood away from traffic lights occasionally. Still won’t be re fitting it though.
Thanks for all the responses
I'll look into getting it removed as it can't do any harm.
The gear change itself is not difficult it just seems to be a bit sluggish as I accelerate away in 2nd
Its like I've dumped the clutch if that makes sense?
But other times its really smooth and with no issues
Gearbox fluid change, ZHP Shift knob and removing the CDV made a big difference for me.
