19” Tiger Claw fitment and coilover advice please
Bewick
I’m going to buy some 19” staggered tiger claws on Wednesday. Have any of you lovely lot had any experience fitting them? I’m wondering if I’m going to have to run spacers to get width/stance of it right to make them fill the arches and not look sunken in the arch. Also I was hoping just to get away with fitting lowering springs (I’m seeing most are about 30mm drop) but I’m worried incase that isn’t going to be low enough to close the arch gap. If I have to run coil overs will I need spacers not to just fatten the arches out but for the wheels to not foul the coilover shock body.
So basically after all that waffle;
How do tiger claws sit without spacers
If I need spacers what thickness front and back
Will springs be enough to close the gap or need coil overs
Do I need spacers to clear the coilover bodies
Thanks Dan
How do tiger claws sit without spacers - They wont physically fit.
If I need spacers what thickness front and back - 15mm all round
Will springs be enough to close the gap or need coil overs - no - they'll look pap on springs - too wide/aggressive fitment
Do I need spacers to clear the coilover bodies - yes - as above 15mm all round
I fitted style 132s which are the same offset n widths as the tiger claws. Had them fitted about 24 hours - they were so heavy the car drove like a builders van, so took them off , sold them & fitted some Style 32's from a 7 series n never looked back!
You'll need 225/35/19 fronts and 235/35/19 rear if you wanna go ahead :thumbsup:
Aw Jamie you’re talking me out of them here 🙈 just with you saying it drives terrible with them fitted 😩
And 1000rr where are you located cos if I pass on these I could maybe sort you out with them. They’re full refurbished with almost as new tyres for £550
Ha have you lifted one up? They weigh the same as a small moon lol
1000rr said:
Are they that heavy??? :o
Yeah honest. Car felt slower, less reactive to steering input etc, just not good at all.
Only my opinion like but I've probably had close to as many sets of wheels as Mr Wilks and they were the worst of the lot on the car imo.
Bewick said:
Ah well that’s them out the window. Gutted 🙈
Id fit them first with some 5mm spacers on the rear & 15mm fronts - just get a feel for them before you spend £££ on coilovers/springs etc - just give you an idea - I might be being pedantic but I just really didn't like the drive.
