19" run flats going in the bin - what's the best replacements?
Nanu said:
Thanks for the advice which I will take note of. Will be sticking to RF's though as I find with the suspension on the 35is they perform better than the same tyre did without on my previous Zeds
If people accept that the 35iS has softer suspension because Bridgestone RFTs are hard, then 2017 non-RFTs by, for example, Michelin might be an attractive alternative. So, the apparently wonderful new Michelin PS4s are 'XL' - as are the Pirelli P Zeros (for Mercedes) - which means that they have stiffer walls to cope with heavier than normal loads. They aren't, however, as hard as Bridgestones and drive much better by all accounts.
I put hankook ventus v12 evo2 on my 28i 19" wheels to replace run flats. They were a good compromise between cost and quality.Run flats really are shocking.
