19" CSL REPS fitted..now warning lights!!
Fitted 19" csl reps and took my coupe out on the motorway and after about 20 mins these 3 warning lights popped up on dash. Got a bit of steering wheel wobble too at above 60mph could it be tracking/alignment needs looking at and caused the lights? Was fine on the 108's I took off. Any help much appreciated.
Are the lights to do with the flat tyre monitor system, as you've changed the rolling radius of the wheel it probably just needs resetting,
Try the reset & get alignment done.
Did you lose hill start / TC too, as those 3 lights seem to be the ABS vac pump, or at least a sensor.
