160K Mile MOT 2004 Z4!
itsjoel
New member
Thought I'd share this with you all...
Not bad I don't think for a car that's used properly and that's on 160,000 miles!
Good on blighty and the MOT test tho....
https://www.youtube.com/watch?v=XiIcuG53h74&feature=youtu.be
Get a mewant leather steering wheel cover. Takes a bit of time to fit but do-able for a novice. Looks factory fit when finished and adds extra thickness to the steering wheel. Costs about £20.
Another 'thumbs up' for royals. Stick around the forum long enough, they pop up on the buy and sell section :)
You're lucky the airbag light was so easy to get rid off! The door is an interesting one, assuming it was the passenger side, would that have also been a fail??
How many laps of the Nordschleife did you do in Germany? And did you have traction control on or off?
If the pads were new before, then they shouldn’t have worn to the wear indicator, especially as the rears do a lot less work than the fronts.
Also your steering wheel looks like it just needs Dodo Juice and some elbow grease. Personally I wouldn’t bother with a re-trim unless you wanted to go for Alcantara.
Welcome Sir.
I did comment on the Carley and if ever you want to come Romford I have a list of Z4 Coupe, 03 M3 and M3 comp for you to try. Once again. Welcome.
Hi and welcome to the forum Joel - eventually! :thumbsup:
I've enjoyed watching your videos, and my car appeared briefly in the one you did at the Ace Cafe in 2018!
RBM is a good choice too - my car has been there a few times this year. The car sales place next door only started focussing on Z4s after they saw how many had been through Ross' workshop. :lol:
And congratulations on your mileage milestone!
Why has it taken you this long to join the z4forum! I've been following your IG and watching your YT from the beginning - I'm that person who persuaded you to get a backbox delete - not sure if you remember 8)
Finally made it to the forum then mate. You sticking around for a bit? I'm not too far behind you on mileage, still going strong
Stevo1987 said:
He is just a kid who makes videos on The Tube and he reeled a few of you in. :rofl: :rofl: :rofl:
I've met Joel a few times, did some coding on his zed at Ace before he got into promoting Carly. If joel has disappeared then that really is marketing 101 lol
Joel, out of interest I also dropped in on your YouTube comparing an E85 2.5 Vs your own 3.0, within a few minutes you say you think yours has the M54 block, you are not sure if the 3.0 came with M-Sport suspension as standard or whether the 2.5 you are driving has it, also your 3.0 is on 17" wheels which is making it ride lower. Top stuff mate I'll ditch the lowering kit I was about to fit and drop down the 17's, thanks :thumbsup:
..... and I'll pimp this one for you because as the title suggests, it does genuinely tell me something I didn't know about my Z4 namely the "hidden Z" in the design, thank you :lol:
https://youtu.be/i5djQZukIQ8?t=339
Interestingly if you look at the side window it forms a 'D', the door shut-line is clearly an 'I', the wheel arch an inverted 'C' and I'm sure there will be another letter but I'm not sure what the hidden message is? :wink:
He’s been around a couple of years guys, albeit under a slightly different username.
https://z4-forum.com/forum/memberlist.php?mode=viewprofile&u=29006
