12V ignition power source from where..?
Argenta
Well hello, I've been trying to install a speedcamera warner in my Coupe which feeds on 12V.
Preferably the power which is only on when the engine is on, i.e ignition mode.
Where can I find a suitable source?
I've been looking under the ashtray area but the ashtray lamp actually gets only 5v and the cigarette lighter has constant live 12v.
Cheers!
For my dash cam I used the purple/white wire in the rear view mirror.
If you are looking at the lighter area then go across to the fuse box and use a fuse tap on a switch fuse.
