1 or 2 squeaks and rattles
JonnyB
Buckinghamshire
Hi guys,
New to the zed club but unfortunately I have started to hear 1 or 2 squeaks and rattles from the car. I know it is 8 years old now but I want it to be perfect ☺, so much so I have just spent £100 on cleaning products for it!
1 - i think this is to do with the brakes. I can only hear it below 30 mph and it is mainly when I as pressing my brakes but sometimes can be when I'm not. It's not overly loud but loud enough to hear with the windows down. Any ideas?
2 - rattle on the door speaker. Rattles a bit when the speakers are on or off. Sound is not distorted at all but again it's still a bit annoying. Could this mean I need a new speaker? Would this be expensive to replace?
I ve got rattles from the plastic frame strut on the drivers side windscreen, Just jammed some foam down it...seems to have cured it, might work for your door speaker.
That's not a bad idea! How did you get it in? Is it easy to take the plastic surround of the speaker off?
Anyone any idea on number 1? I am pretty certain that I may just need to lubricate the back of the pad. Is this easy to do? What is the best stuff to use? Also if I wanted a garage to do the work then how much would they charge?
A thin dab of copperslip should suffice to damp down any rattling-it's usually done to combat squeal, easy half hour job.
Regards
Regards
Awesome! Thanks, i will buy some and give it a try tomorrow.
