andrewnmoore
Hello all
I have an 08' E85 se and I'm having an utter ball ache trying to find the correct oil filter removal tool. An 88mm is very slightly too big and I'm worried about causing damage to the plastic casing if I try to remove it. And an 86mm is too small and won't fit over the filter cover! (both are Sealey products if this is relevant to know). There are 16 flutes around my filter case and both tools I have are 16 flutes.
From what I can see most models need a 76mm tool, anyway, I'm at a loose end with this one.
Am I being stupid? Anyone out there with the answer?
Thanks alot in advance
Andy
Andy
I will go ahead and order that one. Thank you very much for your help, really appreciated. And I'll get some pics up soon, after a good polish...
