Handbrake module wet .... completely immobilised car. Fixed.
johnsi02
 Glasgow
Hi,
Went to the 3.0 Sdrive to head off to work this morning. Dead as a Dodo. Yellow ramp service light and yellow brake warning lights on dash. Nothing from the starter motor when the button was pushed.
Great ......
Got out Protool and it threw up about three thousand codes including multiple DME, CAS and just about everything else.
So began the fault finding ..... battery voltage ok, unplugged the Intelligent battery sensor, checked fuses etc. All the usual stuff.
Still dead.
I'll cut a very long story short to save your sanity.
Dismantled the boot lining and found the inevitable water under the battery and around the roof CTM module and the handbrake module. It's been VERY wet in Scotland the last few days. The handbrake module was sat in about 2 cms of the wet stuff. Managed to get it unplugged (not easy) and sprayed the pins and the connector with contact cleaner and dried it out.
Reconnected and, hey presto, the car came back to life.
Rescanned and cleared the faults and none have come back. The water was clearly causing a short and locking everything else out.
At least I now know the plan for the weekend. Hours of finding where the water is getting in because, sure as night follows day, it's going to keep raining in good old Scotland.
Happy Wednesday everyone. May your boot stay dry and your warning lights stay absent.
Ian.
Make sure the units are all properly dried out..there are at least 2 others in the same bay same location…long term corrosion from just being damp is more fatal
Check the vents on both sides of the car if dirty, sandy or loosened. It's a cheap fix and can be replaced from the inside of the trunk without dismantling the rear bumper.
Robbi,
Thanks for the reply. Much appreciated.
Please can you describe what 'the vents' are?
I'm not sure what you are referring to.
