The CTM is not that smart and a few corroded pins and all sorts of strange sh!t happens..good result ..Well f**k me… I traced and removed the roof module and then removed the weird tape the previous guys had put around the lines leading up to it, to my surprise though, no cuts or mods made there, anyways, while I had the module out, might as well clean the contacts with some Crc spray..
So did that left to dry for 25 mins and then plugged it all back in..
Temp sensor code GONE!!!!
Hell yeah!!!!
Onwards and upwards
(I wonder if hotwiring the pump motor did anything like maybe it was stuck?) or maybe it was just dirty connection?)
Extended lighting …part of the extended lighting option packView attachment 298709
While iam there, I took the rear shelf apart, with the speakers in it, what are those two things I circled? Are they just lights? Or some weird infra red thingy? lol
Go for a romantic evening cruise…it will impress somebody!Cheers , appreciated.. I can discount that then..
TBH, that is wrong.The pump only runs in one direction,...
TBH, that is wrong.Violet - hydronic oil temperature, presumably it doesn’t matter which way they are connected.
Thanks Robbi, appreciated mate.That is wrong.
The pump even changes it's rotation while opening as well as while closing the roof. That's the only reason there are two salmon relays mounted.
[Dropped on V's request]Hi Robbi,
please don’t thread crap in my thread, I don’t do it in yours, if you have something of value to add, then fine, you’ve added nothing but insult, what you did add was sorted in post 4, which you would have know had you actually read the thread.
As a common curtesy, please remove your post, and please refrain from mocking or insulting posts, which serves no one but your own state of self satisfaction at the cost of someone else’s.
OMG!
Better you stop digging sooner than later.
It doesn't help neither you nor anybody else to place new speculative wordings into this forum.
So much nonsense in this thread doesn't make any sense to be commented anymore!
That's it, no more comments
- The plate is from the luggage compartment.
- Your "round sensor" is a permanent magnet.
