Öhlins damper settings corrected — and an accidental experiment
To err is human. To err on all four corners simultaneously, and then not notice for several weeks, is the mark of a muppet — but as it turns out, an instructive one.
When I set the Road & Track dampers after the spring rate change, I did it in the garage in stages. What ended up on the car was 9/7 front and 7/9 rear — counting clicks out from full hard, so lower is firmer. Nothing matched side to side on either axle, and one corner was still sitting on the number that suited the old Öhlins spring rates rather than the new ones. Quite why or how I got there I'm not sure. These things happen, especially if you get distracted or stop-start a job — the "now what was I doing" moment, or worse, just plain forgetting. Heh ho.
I then drove it for several weeks and concluded the car rode better than at any point in six years of ownership.
The changes have come in overlapping windows:
- Tyres. Continental SportContact 7s, 235/40 R19 front and 275/35 R19 rear, up from 235/35 and 275/30. That's about 12mm more sidewall at the front and 14mm at the rear. For context, the factory 225/35 and 255/30 run-flats left roughly 76–79mm of sidewall, which is below the point at which a tyre can envelop a sharp edge rather than transmit it.
- Springs. Up from Öhlins' stock 60/70 N/mm to 80/96 N/mm. At unchanged perch positions that recovers a calculated 12 to 16mm of bump travel — the car had been riding too close to the stops. Happy to show the working if anyone wants it.
- Rear anti-roll bar. H&R, maximum setting.
- Damping. Which I then got wrong.
Like so many parts of this journey, I didn't end up where I thought I was going to be. There's no way of telling which of those changes did what — they overlap too much. A car with four dampers set wrong, one of them by a full generation of setup, still felt transformed. Whatever fixed the six-year harshness problem, it wasn't the clicks. It was sidewall and bump travel. Six years of harshness was a system-matching failure, not a single bad component.
On the tyre itself: the SC7 is where I've ended up after a good deal of switching about, and the reasons are boring and mechanical rather than tribal. Wet composure, and a sidewall that loads predictably rather than going vague and then sharp. A tyre with a soft, unresolved carcass would have wasted most of what the size change bought. Pressures 34 psi all round.
The clicks are still worth getting right. Corrected to 7/7 front and 5/5 rear — a step firmer at both ends and more at the rear, which is where the load is going. The Öhlins R&T runs a single adjuster and it's rebound-dominant, so firming it buys body control without spending much of the compliance the sidewall change just paid for. That's the theory, anyway.
The test is four days in the Dales with a passenger and a full boot. Rear-biased car, meaningful added rear load, and a genuine spread of surface from decent A-road to the sort of patched, cambered stuff that finds every fault. If the rear is over-damped I'll know within an hour and it's a two-minute job to back it off in a lay-by. The fronts stay put unless compression becomes properly objectionable — the front right collar is still seized pending the winter overhaul, so that corner is my fixed datum and I'd rather not disturb the one thing I can't currently reverse.
