Abs pump coding
Walker
 Flint
Hi guys needing to code a second hand abs pump to my car, I have just installed
BMW 1.4.0 but a novice when it come to the computer side.
Any help? Thanks
I haven’t used scanner 1.4 to code a pump but I think it’s as simple as selecting DSC/ABS and changing the vin to match the car
You may still need to calibrate the pump using inpa
I don’t think so as you need to do the 4 specific steps on inpa which I can’t recall
May not need calibration just saying I think you will if it’s been changed
I fitted second hand abs pump, didn't need coding. Just made sure it had the same part numbers.
Common failure part inside failed.
