You looking at doing something like this:
If you're referring to one I have made in the above video then I have adapted it so that a wireless battery pack can be used. I have a Samsung so the battery pack fits snug into a hole because it doesnt have magsafe. If you are using an IPhone then a magsafe battery pack would work better.This is awesome. I just on an E85 and when with the proclip mount, but it still feels a bit out of place to me.
It would be great ideal if you could make this work with MagSafe and a really low profile cigarette lighter adaptor. I'd definitely buy one.
This could also be an option, rather than using the flush mount usb charger in the 12v port, as it'll move the wiring out of the location where the holder will want to be sitting (if that makes sense?). It'll stop 2 things (mount and charger/wiring) fighting for the same space.
Hi all,
Thought this would be of interest to people... My E86 came with the panel above the ashtray with the aux port cut out. I have Bluetooth audio, so don't need an aux port. I do need somewhere to charge phones etc though, and thought that panel would be ideal...
After some googling, I took a chance on a second hand BMW dual USB-C charge only (no data) panel/socket. It turned up, and fits perfectly into the aux cutout!
I haven't wired it up yet, but it'll be easy - one wire for earth, one for power, and the other for illumination. I can't be bothered to tap into the cars wiring for...
- TriggerFish
- Forum: E85 / E86 Z4 discussion
No worries - replied on the other thread in case it helps othersSorry, I didn't realize that was your post and could have replied here.
It's a good idea. Where did you pull power from? That's the only thing I didn't understand.
Hi all,
- TriggerFish
