Theoretical engine swap
Osprey6010
 Birmingham - England
Odd question that might spark some discussion, but I'm looking through 6 cylinder z4s, not looking to buy yet, just looking for general prices - unrelated.
I was just wondering if theoretically you could swap the n46 to an n52 (for example). I know "technically you can swap most engines", but I'm talking, "easier" than most other engines.
From what I can work out so far, all the mounting points and general hardware looks the same between a 2.0i and a 3.0i, except there obviously more engine.
Changes I'd imagine it need would be stuff like new ecu (or at least a remap), and potentially a couple more mounting brackets, new exhaust possibly.
Not looking to do this, as it would cost the same as a new z4 and has a million things that could go wrong, I'm talking purely hypothetical, for a nice bit of discussion.
I'd guess:
- Engine and accessories
- Engine mounts
- exhaust
- gearbox (clutch, flywheel)
- propshaft
- engine wiring loom
- coolant pipes
- ECU (and either EWS delete or complete with EWS and key set)
To to forget you'd probably wanna upgrade the breaks, the diff. might be the wrong ratio, and the driveshafts will be much weaker/thinner.
If you got a breaker, it would be easy enough. If you were trying to source all the parts individually, I think you'd constantly find little bits that you overlooked.
Yes it has been done.
Here's some light reading for you!
Going between engines that were both fitted to the same chassis is easily do-able as the parts will all work and be available. Probably the cheapest way to go about that is to buy a written off one and rob all the appropriate bits. For a 4 to 6 pot conversion most of the work needed is probably non-engine - springs/shocks, diffs & brakes.
I (equally hypothetically and more for the intellectual exercise) like the idea of putting in engines that were never fitted. So an N54 or a V8 etc into an E85. As far as I can tell, for a long time, BMW had very standardised ideas about mount points and commonality of parts. Look up many E46/E85 parts and they were in circulation since the E30/E34 era which makes half the fitting battle a lot easier. There was some conversion I read about many years ago (no idea what it was, so let's say a V8 into an E46) where all they had to do was go and find some E30 engine mounts to get it in the right place. Something like that anyway. Another one is oil pans; some engines get a different pan depending on what it was fitted to giving more options for clearances etc.
I noticed recently that retro-fitting the ZF 8-speed box into E53 X5s is a thing - that seemed something I would have thought very impractical. And someone breaking an E70 X5 40d (twin turbo) as they were fitting the engine & gearbox into a 1 series.
Well you might as well go big or go home. :LOL:
A long time ago someone on here fitted an S85 V10 from an M5 to a Z4.
I'd say the cheapest way to swap from an N46 to N52 would be to sell it and buy one that BMW fitted the N52 to in the first place :)
It would be normally but Jingle made that swap because his E85 was Alpine White, and only two 3.0Si E85s that colour were registered in the UK so he'd probably still be waiting to find one!
That' brings me nicely onto my next question then, I was also going to ask if anything special like a v8 swap had ever been done or could be done. My thinking was there's the space for sure, if you get one with a shallow v angle it should fit?
If anyone knows of anything like this, I would be interested in some more light reading, thanks
The ally V8s are apparently a reasonable option as, IIRC, they're not that much heavier than the S54.
As above the V10 has been done and I believe one of the V12s has been done as the engine bay is already long enough for a 6pot bank. But it did make the weight balance something like 70/30. That might have been a Z3 rather than a Z4, it was quite a while ago but the same idea.
Shame no one told him that cars can be wrapped or resprayed:rofl:
I always said that would be the route I would go if my S54 went bang in a big way.
A couple of years ago, I almost bought a manual S85-swapped E46 M3 to use as my daily driver but I came to my senses just in time!
Might try and find a V8 swapped one, sounds interesting.
