What did you do to your Z4M today?
Yep will post a full list of the bushes I ordered once I've committed - aiming to get them on order end of the month.
Front end I kinda wish I'd got on and done the millway stuff there, but I went for powerflex black series for the front lollipops and arb bushes. I've also gone powerflex black for the rtab bushes and rear arb bushes. I'm gonna leave those as they're only a year and a thousand miles old, but everything else at the rear is getting the millway solid/spherical treatment!
Cheers. I’ll look into Millway
I’m still using the OEM clutch and flywheel. Due to the change in height at which the clutch disengages, I suspect the clutch is nearing the end of its life (and/or the slave cylinder is failing). Ideally, I’ll fit a lightweight flywheel when I replace the clutch, so it will be good to have your feedback.
Rigtho sorry mate not my finest reading this morning, trying to keep up with the kids in the playpark on holiday 😅🤦🏼‍♂️
Arrived, but unfortunately a bit late for the Le Mans trip (some kind of family-related issue at Pedal Haus).
Into the cupboard they go, and back to work… :rolleyes:
