Nice to hear, mine came with upgraded JBL’s in the front . I have the exact same Focals for the rear as one of the standard ones is during along with the genuine lower grills and fittings from a premium audio car along with a matching focal amp and 4 ton of sound deadening.Today I upgraded speakers, FOCAL 165 AS3 serie and I have to say that its like night and day. If anyone is considering this, don't think about it anymore. Do it. But don't forget the mounting beers...
Seeing the water would have ruined my day!Put the Z4C on the CTEK. It is not getting enough use at the moment as the E46 has the winter tyres.
E46 - ran a full Carly diagnostics and cleared fault codes. Also checked out the battery as it seems to lose charge real quick. Once i pulled the boot floor, side panels and various fixing brackets out I found two issues. First is that the battery is sitting in about 2cm of cold water. Second is that it is a BMW battery. As the car only went to BMW for it's first three years I assume it is still the one it was built with 17 years ago. I think that may explain why it is starting to get a bit weak :?
Do you have a link to the rear hoses you used, pleased? I was going to get a custom one made up to replace the metal middle part, but maybe there's some off the shelf ones?Replaced both rear brake pipes, thank you Mr MoT manand ended up fitting braided hoses all round as well - gets rid of the rear hose to crimped steel parts. x2 ARB bushes and the final nail in the coffin a small cut in the tyre, of course its to chords
MPS4's
blasted and painted the calipers and carriers whilst all 4 wheels where off. Bring on the sunshine![]()
https://www.ebay.co.uk/itm/153138920241 rears are 2 piece to allow mounting to the original bracket on trailing arm. a bit fiddley to connect due to spanner sizes,, also found you need to really nip down the brake pipe fitting.Do you have a link to the rear hoses you used, pleased? I was going to get a custom one made up to replace the metal middle part, but maybe there's some off the shelf ones?
