Hi everyone,
I recently bought a 2007 BMW Z4 E86 3.0si that already had this issue.
The car came with two keys:
The important point is that unlocking has always worked perfectly with key #2. However, locking has never worked since I bought the car.
I have now been using key #2 regularly for about two weeks. The car starts perfectly with it, and the remote unlock function works normally, but the remote lock button does nothing.
I have already tried the key initialization/synchronization procedure, but it did not solve the problem.
There is also something strange: if I manually lock the car using the key in the door lock and then press the LOCK button on the remote, the interior lights come on.
I’m wondering about the GM5 module, the remote receiver/antenna, or another part of the central locking system.
Could the EWS system be involved, or is it only related to immobilizer/start authorization?
What would you check first, and can the GM5 or remote receiver be properly diagnosed with INPA/NCS Expert/ISTA?
Thanks for your help
- Key #1 is physically damaged, so I understand why it doesn’t work properly.
- Key #2 is in perfect condition, but had barely been used for around 20 years.
