Oil level
MikeyH
Elite
 Devon
Hi all, the photo is a bit blurry, sorry, but the level is above what I always thought was high, it’s in line with the number 1 on the code. I’ve just had an oil service. What do you all think, is it okay? Cheers, Mike.
Previous post on this here
Thank you both, I'm wondering if the dip stick is the wrong type now as unless it is kept to your no 1 it beeps and the oil light comes on. Also I presume the mechanic put in the correct amount of oil 6.5 litres. It's now up to the number 1 moulded on your dipstick. Mike.
Did you remember to run it until the engine is hot, turn off and check a few minutes later? If you check it cold all the oil that should be in the filter can drain back down and make it look too full.
Yes enuff_zed I did. We went out for a run to Totnes, stopped for coffee by the river and came home about 9 miles there and 9 miles back, I waited about 5 mins and then checked it. I will try again tomorrow. The mechanic didn't warm the engine first before he drained the oil, which seemed a bit odd to me but it was a very hot day 29 C, so I thought maybe that was okay. I know he didn't because he was doing it on my driveway. Thank you, Mike.
My 2.2 has the same dipstick as this.
If the oil only looks overfilled when cold don't worry about it, besides it will soon need topping up, I've moved back to 5w 40 as I was getting fed up of the oil light coming on
Mine is the same, the annoying light and that beeeeep:rofl:
Okay so to close this, I checked the oil after a run on Saturday, I left it for about 5 to 10 minutes I think and it was still showing high. Today after a long drive I checked it in the time it took me to open the bonnet and the workshop to fetch some tissue, 2 minutes?, this time it was correct. So it needs doing as quickly as possible it seems. :thumbsup: What a fussy little madam it is, unless it has a really bad leak or burning it away.:eek:
It's an old BMW. If it ain't leaking it will be burning it.
My M54 is going for an oil change on Wednesday. I've asked them to put 17 litres in to 'future proof' it from that cnut Trump.
And I am actively saving our old chip fat for next time. :)
