Overheating & Bonnet release cable
Zowen
 Wigan
Hi Guys,
I have a BMW Z4 e85 3.0l auto from 2003
First I'm seeking help with an overheating issue. When the car is running it'll stay at temp for about 20-30 mins and then start overheating. This is when it's stationary I've not been able to try it whilst its moving to see if it still overheats.
It has enough coolant in, I have a feeling maybe the coolant line may need bleeding? But I'm unsure on how to do so if anyone can advise or advise what else they think it may be.
Secondly is bonnet release cable. My cable has been on its way out for a while struggling to open the bonnet. I believe it hss now snapped as the lever is completly floppy and has no tension. I have purchased a replacement front cable as my understanding is this is usually the part that goes, but I'm unable find any video or anything with instructions on replacing it, if anyone could assist that'd be great.
If you have any questions or want more info feel free to ask!
Thanks,
Owen
Overheating can be a number of things including an airlock, thermostat etc
However I’ve had that before where the water pump impeller had failed and the flow was about 20% or normal. I’d check that
Bonnet release can be made by popping the grilles out and manually tripping the catch by hand or with a screwdriver, or pulling the cable. If it’s stiff have a helper press down on the bonnet while doing that
Have you got any codes? The thermostat has a secondary heating element in it that can fail. This is used to vary the operating range of the thermostat.
I have the bonnet open, Im wanting to replace the actual cable.
I'll check to see if I have any codes, as it sounds like it could be as the temperature is just fine for 20-30 mins then starts raising.
Bonnet cable runs from the cable handle, down to the drivers side engine bay where it joins the next part of the cable via a joint, then from there to the actual latch
I have both halves of the bonnet cable here in Coventry if required. Others closer to you may also.
