Hi everyone,
I'm hoping someone can point me in the right direction.
My 2003 E85 3.0i has developed an intermittent clunking noise at low speeds. It happens even when I'm driving in a straight line, and my passenger said they could actually feel the clunk through the passenger-side footwell.
My first thought was suspension, so I had a good look underneath it. I checked all the front suspension and bushes, I then did the same at the rear. Nothing jumped out at me, and everything felt solid with no obvious play.
The thing that's really thrown me is that I drove down a hill and put the car into neutral, as soon as I did, the clunking disappeared. That makes me think it probably isn't the suspension and is more likely something that's only making the noise when the drivetrain is under load.
I'm now starting to wonder if it could be something propshaft or diff related, but before I start ripping the exhaust and heat shields off
I thought I'd see if anyone has had the same issue.
Has anyone experienced anything similar on an E85 or got any ideas about what else I should be checking?
Thanks in advance.
P.S here's a picture of the culprit, because every forum post is better with a picture
Thanks in advance.
