So I have had some roof issues.
It was intermittant but now pretty much in fail mode now.
The roof works every thing , bar :
1. when fully open, the car does not beleive it is done, and I get red LED on the roof open button, although mechanically everything is in position.
2. when it was working, and I could close the roof, it also did not beleive it was fully done, but it came and went, the troubleome aspect being I couldn't operate the side windows.
However,
now i have the main issue which is I can't close the roof, it does everything until the double stack roof+window has to move the window back to the rear.
1. boot opens
2.double stack moves to roof position
3. boot closes
4. whirring, but no movement of window back down.
I have renewed the wires visible on the main hinge both sides. Checkking the replaced bit of wire (x6) showed the removed bits all seemed to have continuity.
I check the connections for the hall sensor in the boot ram, and the 2x microswitches.
I read these should be 2.7ohm when pressed, about 500 ohm when open. I'm getting 2.7 regardless, on both sides.
The internet seems to think this is very rare and unlikely.
It's £145 quid x2 from bmw for the switches -- if they dont read 500 then both a knacked, worth getting the replacements ?
However,
1. boot opens
3. boot closes
Seeing how this turns out. I’ll probably start my own diagnosis either tomorrow or the day after.. fingers crossed for the OP.
